What do you honestly feel would be the better option to choo
MaverickHBK
Post by MaverickHBK »
What do you honestly feel would be the better option to choose for the
New version of resolume. A Mac or PC?
Re: What do you honestly feel would be the better option to choo
We develop Resolume 3 on MacBooks Pro and they are excellent laptops for Resolume 3. Because new PC laptops come with Vista installed we actually recommend a MacBook Pro and run Mac OSX if you are buying a new laptop. Vista is unfortunately a lot slower than Windows XP Pro.
