Mask causing darker image
flo
Post by flo »
I found another issue.
When I apply a mask to a clip or a layer (PNG oder JPG image with 100% white and 100% black parts) the part of the videoclip which passes the mask gets darker. I can't really measure it but it's maybe 10% loss of brightness.
arby
Re: Mask causing darker image
Post by arby »
i have to agree on that issue...
definiatly a luminance drop when the mask is applied
Yes we can confirm this, it's on our todo.
gradek
Post by gradek »
How do you apply a mask to the video?... Can you have video masks or just photo?
flo
Post by flo »
You can apply masks at a clip or a layer. Look at the properties panel there is an entry called mask. Just drop your mask image here. As I know only still images can be used as masks.
______________________________________________
Sys specs:
Arena 7.14.1 / MacBookPro9,1 / NVIDIA GeForce GT 650M / OSX 10.15.7
