i really miss the the custom masks for transition. especially the soft masks i used to create great compositions.
also missing: the bounce button and so on to trigger the transitions with the beat.
but i love you, because of the audio support, i was always begging for.
DAS BEN
blend mode mask transitions
Re: blend mode mask transitions
You can animate the layer opacity just like any other parameter on the Layer properties panel:
- Attachments
- Picture 4.png (28.07 KiB) Viewed 4328 times
custom masks with alpha are great. but if i want to change the mask during a show, i have to search for the rigth file on my harddisk. a dropdown menue like in the previous versions would be great, like the mask and transition folder in the past.
