converting recorded clip
marco_
Post by marco_ »
i'm not able to convert files recorded in resolume: when i try to convert with premiere or after effects, they give me different error depending on the codec i choose,
i just wont to compresse the file ( uncompressed the file are too big,
doas someone have the same problem ?,
hi
m.
dotti-research_
Post by dotti-research_ »
I don't have any problems with converting the recorded clips. They are uncompressed in 320x240. Be carefull with resizing and compressing with i.e. indeo. Indeo needs dimensions dividable by 16...
norm
marco_
Post by marco_ »
may be a problem of freeframe version, i will try with the previous,thanx
marco_
Post by marco_ »
the same problem with Resolume 1.1 beta 4,
after effects give error: retrieving frame from video stream, and premiere close. i don't know, i just won't to convert them with cinepak codec.
any solution really bienvenida !
ether_warpTV_
Post by ether_warpTV_ »
try using virtual dub (freeware), or quicktime if you have the PRO version
dotti-research_
Which version of the mediaplayer do you have?
marco_
Post by marco_ »
media player 8 on the laptop (XP) and 9 on the desktop (win2000), but it's the same, also with the pro version of quicktime,
anyway.. :(
can you email me on of the clips? so i can try and see what s going on ... this should not be any problem we have done in a million times before.
bart@resolume.com
well ... maybee not a million ...
ether_warpTV_
i did have a weird bug on one of my PCs where once i installed media player 9 half my movie files wouldn't play - it was a while ago and i can't remember which movie formats it was - but you could try a previous version of winMedia player...?
