Hi Resolume team !
My resolume 2.41 was almost crashproof for over two years on my laptop (asus w3v, 1,7 pentium M, 1024 gb, radeon x300, xp sp2) everything was going perfect and one day resolume didn't start. I could see the interface for a second after start and than resolume crashed. A reinstalled DirectX - no help. I did a Windows reinstall - 1st time resolume did run once but the second time not. After second Windows reinstall i installed only video drivers and all essential stuff - no help. Everything else (other sofware) works as it used to.
Do you have any idea what could be the problem ? Possible hardware damage ?
here is the log file: http://decorum3.net/resolumelog/
Best!
Jan
Resolume started crashing on startup
Re: Resolume started crashing on startup
I probably do not know what is wrong. The only help I can offer is that if you have recently installed any vst plugins that R3, (and probably R2.41) does not like, that is a possible reason for Resolume not to start up.
vst's are irrelevant to version 2 resolume as its video only.
Same here
Totally rock solid and than piece of unstable sh**!
However my became unstable after reinstalling windows (service stuff).
For now seemed OK but now started crashing after exiting it.
Hope it will stay like that, hm...
Anybody knows why is this happening ?
Seems like the problem lies in one of the plugins, but don't know which one (fugVideoSampler, PeteLiveFeed or similar).
Works for now
Works for now
