Bump on clip trigger
cat
Post by cat »
I seem to be getting a bit of a bump on clip triggering, ahh I was and then it crashed, heres a consle log, using dxv on osx
Stack.zip
dump
(3.79 KiB) Downloaded 664 times
No still getting the bump, its playing a frame from a few frames in before starting play back from frame 0, this on triggering a new file rather than retriggering a playing file. Doesnt seem to do it to photojpg files though
racher
Re: Bump on clip trigger
Post by racher »
Yeah, I've been having the same problem on XP Pro SP3 with the DXV codec. No other codecs cause this problem, but the DXV codec does have the best performance by far. Such an annoying little bug for a codec that works so great!
Of course, I'd prefer an alpha channel with the codec!
-B
VJair
Post by VJair »
ive noticed this too. it doesnt happen if the clip is bpm synched or if you use the "continue from last position" playback mode ( cant think what its called.... the one where it remembers what frame the vid was at before it was replaced and when retriggered it starts from that point )
