No output video
secretkillerofnames
No output video
Post by secretkillerofnames »
So I set up and test R3 with a projector and everything is working ok.
I save the setup and close R3 as I'm not performing for an hour or so.
Then gig time comes, turn on the projector again and then load up R3 and there is no output. The projector is getting a black screen - if I go windowed on display 2 I get the resolume avenue window header displayed but no video is displayed through the projector or in the output window. I tried reloading R3 twice - same deal. Sound was fine so I ends up just playing with audio. Am I missing something? Apart from some video :P
secretkillerofnames
Re: No output video
Hi Hi!
I see you found my blog! Thanks for responding.
Attached is a zip of the log file - the important dates are the 29th March - you will see a lot of activity around 10pm which is when the problem occurred. I also just tried to load Avenue up then and had to force quit as it presented me with a totally blank screen except for the tool bar, no decks, couldn't quit as normal or load any files.
Hope you can solve the mystery.
chrs
Lloyd
Resolume Avenue 3 log.txt.zip
(4.39 KiB) Downloaded 529 times
