so what i'm missing is something like in ae
an effect layer...
shoult be handeled like a layer and can be dropped as f.e. 4th layer over the first 3 to give all layers among an effect like f.e. a blur... and on the 5th layer i can play a logo or something which is not blurred..
hope it's clear what i'm meaning
the next thing which woult be really cool is text animation native in resolume...
so that you can type a text, chose the font-type and animate it with the parameters and effects in resolume!
also for some logo fonts this shoult make a simle performant and nice effect!
is there something like this on todo?
if not, why?
edit: i think the text should be less the problem expect the osx/windows fonts maybe!?
the effect layer thing might be complicated.. cause it's between the 3 steps comp, layer and clip...
maybe there is a way to copy layer properties/styles (which don't works for me so long cause layer properties won't work after some time mixing)...
and sry for questioning, can i copy effects from f.e. clip to layer or comp by dragging? too lazy to start up now but will look for it next time, woult be also a nice feature if not yet existent
