BMP not running
TheSaintPD
BMP not running
Post by TheSaintPD »
Hi
The BMP does not seem to be running on our new visual machine. I tested the new release on another machine and it worked fine. I cannot however get the BMP to run on this machine.
Processor : Q2800 2.33Ghz Quad Core
Ram : 4Gb DDR3
Graphics Card : MSI N250 GTS
Please help
Rene
Re: BMP not running
Post by Rene »
i had the same problem with 3.0.0 - changed something in the audio settings and it works now. ;) - I think is was something related to ASIO.
TheSaintPD
Re: BMP not running
Hi
Thank you for you input. I checked the Audio drivers and settings without any luck. I am not sure whether I stated the problem correctly the BMP counter that automatically starts running when opening the program (1.1 , 1.2 , 1.3) does not start and is stuck on 1.1.
Thank You
fire17
Re: BMP not running
Post by fire17 »
i am having the exact same trouble as yours. BMP stop running. at same time the FFT and output doesnt work.
i did try to change audio preferrence but audio devices seems disappreared. what is your sound card. mine is Realtek HD, the built-in sound card comes with MSI X58M mainboard.
Re: BMP not running
The BMP clock is dependant on the audiocard because htis provides the best accuracy so there is probably something wrong with the audio in your computer.
Please send me the log file that Avenue creates on your computer:
MAC: /Users/[username]/Library/Logs/Resolume Avenue 3 log.txt
PC: C:/Documents and Settings/[username]/Application Data/Resolume/Resolume Avenue 3 log.txt
Hopefully that will show us what is going wrong.
fire17
Re: BMP not running
Post by fire17 »
bart wrote:The BMP clock is dependant on the audiocard because htis provides the best accuracy so there is probably something wrong with the audio in your computer.
how can i send u log file, i tried uploaded files as attachment in either private msg or in postreply, it said "The extension txt is not allowed."......
GeeEs
Re: BMP not running
Post by GeeEs »
change the extension to something else, or pack it in a .rar/.zip
Re: BMP not running
Please email it to us: mail@resolume.com
