video footage dxv problem in Avenue 3.0.1
illo2
Post by illo2 »
hi everybody!
my videoclip dxv had no problem in avenue 3.0.0 but, when i've installed the upgrade to 3.0.1 all my clip are with noise and striped... if i use quicktime or vlc are ok, out of resolume. i've reinstalled avenue (last upd) and the dxv codec package but doesn't change... if i use avenue 3.0.0 everything is ok! do you have any idea?
i've a macbook pro 2.6ghz intel core 2 duo 4gb ram nvidia 8600m gt, latest osx updates
Re: video footage dxv problem in Avenue 3.0.1
Can you please email me one of those files? mail(at)resolume_com
vexmand
Post by vexmand »
I've just had the same problem
(I'm running xp on a dell m170)
vexmand
Post by vexmand »
I just had a go at re rendering my footage and found that if i change the pixel ratio to 1.0 my clip runs without the distortion. Before I had set it to 0.9.
