Ok so i wanna know if i can change output resolution for each of my cards. Here is a little Techie info on wha ti have and how i run it.
nvidia 6200- interface screen -( 1 DVI, 1 VGA, 1 SVIDEO) pci-e
nvidia 8800 - Output source (1 DVI, 1 vga 1 svideo ) pci
Nvidia 9600gso - Output source ( 2 dvi, 1 HD ) pci - e
NOw i run in different situations, but i always use my 6200 for the interface . RES 1280x1024. IWould like to run the preview screen on another monitor at 1024x768 off of the other dvi/vga port.
Thats the first thing........
The second on is I wanna run two different resolutions off of my 8800 card. one at 2056x1024 (or 800) The other at 1280x1024 ( or 800 )
Then Finally; on the 9600, i wanna run my HD output at 1920x1080... not using my DVI outputs at all.
So , I know how to change to a custom resolution inside the screen setup file. Is there a way that i can assign multiple resolutions through that same file?
I also have matrox dual head to go, 2 of them. So maybe i could set on output like usual and then change the matrox output to what ever i desire ???? does that sound right??? just an idea.....
Multiple resolution output. 3 CARDS !!! :-)
Re: Multiple resolution output. 3 CARDS !!! :-)
i think you talk about resolume3 and not 2?
otherwise you would have a supercomputer for running full hd in resolume2
so far as i know different outputs are not possible so far in r3, only the preview can be run in window mode which would make the preview monitors possible in different resolutions
running full hd without dvi, shoult also work with component or hdmi or some of this new plugs!
alexius420
I am using resolume 2.41. I love my rig
its a lot of fun. In my screensetup.xml i can change the output width and height. I want to do this to each of my outputs instead of one resolution for all outputs. Any ideas!?!?!?!?
