jpg don't work
beatles
jpg don't work
Post by beatles »
hi
i tried to import a jpg file in a colum. the bar under the window changes to yellow like a object is in the window but i can't see the jpg. also i don't see something in the output monitor (see the attachment)
why does this jpg file doesn't work? i generate this jpg-file in photoshop. the size of the file is 4.7 mb. is the size to big for a import of a jpg file?
thanks for your help
another question: gif files i can not import. does avenue don't support gif-files?
bar change to yellow, but the jpg is not apparent
VJair
Re: jpg don't work
Post by VJair »
do other jpegs load for you in avenue?
post it up so someone can try it out.
beatles
Re: jpg don't work
Post by beatles »
hi
i tried another jpg-file, which works in avenue but it's a lower size (85 kb).....
i can't upload the jpg-file because of the size. there are only 2 mb for upload (attachment) allowed...
i try to make the file smaller and try it again to import in avenue.
VJair
Re: jpg don't work
Post by VJair »
maybe try a different bit rate when saving the jpeg for use in avenue?
beatles
Re: jpg don't work
Post by beatles »
hi
now it works.... ;-)
i changed the size. now its 2.4 mb and it works. i can import the file and see it in the window and in the output monitor...
so i think there is a limit for the filesize...
edwin
Re: jpg don't work
Post by edwin »
There is no file size limit, but there is a resolution limit.
You can only load pictures up to 4096x4096.
We don't support .gif, but we do support .png files, so i suggest using the .png format especially if you need an alpha channel.
