how to get back to clip's properties ?
ondrejsevcik
Post by ondrejsevcik »
when i trigger clip into the composition i can still control it via clip's properties as long as i stay in the same desk.
when i switch to a different desk there is no way how to get back to that clip's properties again, or is it?
and - the same problem as mentioned many times here - changing desks causes at least fatal drop of fps in not crash at all..
thx, bye
zeropoint
Re: how to get back to clip's properties ?
Post by zeropoint »
Re the frame drop while deck loading......for now what I'm doing as a workaround is using a jpg with some animation and FX while the new deck loads.....
Macbook Pro 17" 2.93ghz, 4G Ram, OSX 10.5.7, Live 8.2.2, Avenue 3.3.1, Faderfoxes LV2,DJ2, LD2, Monome 40h.
ondrejsevcik
clever.
thx ;-)
craftycurate
Post by craftycurate »
ondrejsevcik wrote:when i trigger clip into the composition i can still control it via clip's properties as long as i stay in the same desk.
thx, bye
I've reported this before, and I think it's been added to the fix list - if you search the forum you can find the post.
ondrejsevcik
there is still no way how to get to the actually playing clip's properties if you are in different deck.
you have to go back to the deck where the clip is.
or am i wrong?
you're right, but this will be fixed in a future update ...
