How to speed up clips beyond 2x?
gpvillamil
Post by gpvillamil »
I want to speed up some clips quite a bit - as far as I can tell the pitch adjustment in the transport controls only allows for a 2x increase.
Is there a way of getting a much greater increase in the playback speed of a video clip?
edwin
Re: How to speed up clips beyond 2x?
Post by edwin »
Audio clips can be pitched to 2 times the speed, video only clips can be pitched to 10 times the speed.
If you assign a clip to BPM Sync and set the length to a small number of beats you can make it go much faster.
