Hi!!!!
i´m just started with this program and i would like to use it in lives. the question is that i want to play videos sequencially synchronized with the music (only one video at a time), for example, each video can be executed each bar.
I was thinking in working with Ableton Live in order to create live midi files that will launch Resolume video clips, but i think it should exist a better way to do it, shouldn´t it?
Launch video clip sequentally & sync to the music
surucutupa
Re: Launch video clip sequentally & sync to the music
surucutupa wrote:Hi!!!!
That's the easiest way i think, it's not hard to do if you follow some tutorials or read the manual
google resolume avenue sequencer
