Video switches while using shortcuts for back/forward
zerodenominator
Post by zerodenominator »
Hi there,
small bug:
if you use the shortcut keys for playing backward/forward while hovering over other clips, other clips will get triggered without clicking them.
Could you check this one?
Cheers
Re: Video switches while using shortcuts for back/forward
Just tried and that does not happen here, do you use the default keyboard mapping or did you customize it?
