Avenue didn't start today :(
GeeEs
Post by GeeEs »
Today I tried to start up Avenue and a message appeared that my videocard doesn't meet the spec's for running Avenue...
Given the fact that I played a lot with Avenue last months on this laptop this is really strange... ;)
I tried to reinstall NVidia drivers, but no luck so far...
In the logfile I can find these lines which probably generate this error, but I can't figure a solution atm.
Code: Select all
version GL driver main renderer: 1.1.0 atof: 1.10000002
No support for GLEW_ARB_texture_non_power_of_two
nonpoweroftwo NOT supported
No support for GLEW_EXT_framebuffer_object
No support for GLEW_ARB_pixel_buffer_object
Video Engine can't be initialised because one or more vital extentions are not supported
I added the complete logfile to this post.
Resolume Avenue 3 log.zip
(4.48 KiB) Downloaded 465 times
GeeEs
Re: Avenue didn't start today :(
Post by GeeEs »
:? allright...
problem solved...
It probably had something to do with on of these virtual camera tools I installed to play with...
http://www.makesweet.com/webcam/ucanvcam/
http://www.hmelyoff.com/
