Functionality which could be useful.
glasshopper
Post by glasshopper »
Hello.
Based on tests I have carried out the following would be useful additions for a future release.
1. Distinction between the colour coding used for midi / key mapping - ie: different saturation for Composition / Application: Deck / Layer mapping so I have an immediate visual clue as to which mapping I am currently working on. Also clear labeling in the Midi Map panel would help here.
2. The ability to map elements to a midi controller / keyboard even of they do not contain footage - it seems that the current implementation is not uniform for all levels of mapping.
3. As per Resolume 2 - the ability to right click a clip in the clip viewer window and see a popup containing the current clip playback controls and a list of all effects currently applied to the clip - possibly with the ability to remove effects one by one or blind all.
4. Cue point marker in timeline once a cue point has been added - if this translated up to the transport viewer for the layer [ which is a great feature by the way ] it could be very useful.
4[a]. Ability to remove cue points !!!
5. The ability to enable/disable random playback for clips with audio / standalone audio in the prefs.
yochee
Re: Functionality which could be useful.
Post by yochee »
some more ideas.. have phun :D
- subfolders for ffgl/vst-effects
(need to devide between motion effects, colour filters..)
- a possibility to manage separately the output-layers and deck-rows
(i want to switch clips from row 1 to row 2 but i dont want to change output-layers)
- would be nice to be able to view the clips properties and clips effects while the deck of the clip isnt selected
(when a clip from deck1 is playing, but deck2 is visible currently i cant view the properties of the clip by right-clicking on it. first deck1 must be reselected)
- is there any way to get the properties-submenues eg. Dashboard/Transport/CuePionts//Video or Dashbord/VideoEffects some more slim? maybe instead of beneath each other sidy by side
(at least the dashboard, cue point and transport-knobs. by now the windows are too small because of the tabs)
(- additional keyboard mapping eg. for combo-keys via options menu)
thx!
olivepixel
Post by olivepixel »
glasshopper wrote: 4. Cue point marker in timeline once a cue point has been added - if this translated up to the transport viewer for the layer [ which is a great feature by the way ] it could be very useful.
I'd love this feature also, perhaps only visible when the Cue Points menu is expanded.
(sorry for dragging up an old thread)
mfo
Post by mfo »
Nice idea indeed!
Would like to add:
- more cue points (can be optionally)
Also:
- longer or more flexible loop-length in the beatlooper
Anyway, thumbs up for Avenue - good work guys!
Tschoepler
Post by Tschoepler »
+1 for the color-distinction, the subfolders and the cue-points (think they were mentioned before in some other thread)
I've added two tickets to the features list:
#1275 different colour shading for all mapping modes
#1276 subfolders for effects
Cue points on the timeline and longer beatlooper periods are on the list already, viewtopic.php?f=6&t=6584 and viewtopic.php?f=13&t=6430. Unfortunately it's probably going to be a while before we get round to it.
We can see the appeal of more cue points. The idea of the current Resolume interface is to have a few crucial controls at your fingertips, without things becoming too cluttered. 6 cue points give you a lot of options, while still being manageable. If we were to add more, the next logical step would be to make the system dynamic, with a user definable amount of cue points. This would make the interface a lot more complicated. It's something to think about though.
mfo
Post by mfo »
Colored nodes and longer beatlooper periods sound very nice! Hooray.
Concerning more cue points, I perfectly agree with keeping the user interface slim. Thats why I wrote "optionally" -> more cue points could be available in the prefs, but switched off per default. Reason for that wish is my workflow when playing live:
To me its much easier to access cue points rather than trigger clips. I have like 30 clips, each containing several loops or variants that all belong to the "topic" of that clip. Playing live I access these loops or variants via cue points by using the NanoKeys. Thus allows me to actually _play_ the video sequences - quickly and intuitively. And sometimes - just in some cases - 6 cue points are not enough for this technique.
EDIT: Ooops, now I see you wrote "We can see the appeal...",I thought it was "We cant see..". Aargh. Now I've written this whole paragraph..
werlin
Post by werlin »
i just remembered a good one to go with the cue-markers:
a snap button that would allow you to move the in\out markers exactly on top of the cue markers
ex: press snap, move faders, release all and let it play
(of course it would be sensible to add: if out-marker on top of cue>then>the out-marker backs up 1 frame)
We're working on allowing you to set the in and out points more precisely by inputting numbers. That way you could prepare your set more accurately.
Tschoepler
YES!
