Best codec settings
Rising_
Post by Rising_ »
Hi All,
just wanting to know what type of codec/resolution settings people use with Resolume to gain best performance and quality.
Any suggestions that you have in mind.
jim_
Post by jim_ »
resolume reccomend cinepak 320x240 15fps keyframe every 1 sec.
although many find the indeo or midivid codec to be quicker to render and better quality. this'll be determined by your pc etc etc
syzygy_
Post by syzygy_ »
don't use a keyframe every second!
Use a keyframe every frame, otherwise scratching performance will be crap.
cinepak does cause loads of compression artifacts - indeo is much better.
Dan.
martijn - eyesupply_
Post by martijn - eyesupply_ »
cinepak only gives "compression" artefacts when you have very colourfull movies (as in lots of colors), since cinepak is only 256 colours. most of our clips use only few colours (most are based around 1 colour, duotone-like) and compressed using cinepak, 1 keyframe very frame. For videofootage with lots of colours we use indeo (mind you they do not ship indeo with XP SP1 or later! you'll have to buy the codec! :O )
cheers,
Martijn
jim_
Post by jim_ »
sorry! i meant keyframe every frame :) thanks for that Dan!
Yuri Elik_
Post by Yuri Elik_ »
Please can you tell exactly what version of indeo codec do you use and with what settings?
I use indeo 5.0, 100%, 1 keyframe every frame, no datalimit. but ONLY for colourfull clips
tim - warpTV_
Post by tim - warpTV_ »
Hi martijn - what do you use for non-colourful clips?
or do you set data rates?
sensualvibes.6x.to_
Post by sensualvibes.6x.to_ »
i searched for the vj room in soulseek without a result.
was it closed?
anyone still on soulseed?
kel_
Post by kel_ »
cinepak iz shit!
-the best codec for resolume and fot cutting iz mjpeg, qalita 19/20...best!
