"Your videocard has unsufficient spec..." problem
unique
Post by unique »
Hello people!
Installed Resolume Avenue 3.0.0 and after launching it got such message: "Your videocard has unsufficient spec to run this aplication!"
My laptop is:
DELL Inspiron 1525
Core2Duo T5750@2.0 GHz
3 Gb RAM
Grafic Media Accelerator X3100
When I searched on-line, including this forum, I saw that many people on PSs and Macs has the same videocard and can run it perfectly. One guy said that the solution is better video driver, but my is up to date due to dell.com
I have some even more powerful VJ progs running perfect on my laptop and definitely know that it can handle Resolution 3 too.
Can anyone help me in this situation? O_o
HerrNieDa
Re: "Your videocard has unsufficient spec..." problem
Post by HerrNieDa »
you have an integrated Intel Graphic Chipset wich is not supported by Resolume3 (see System Specifications)
unique
Post by unique »
but how it's running on other computers with the same Intel GMA? O_o
HerrNieDa
Post by HerrNieDa »
Minimum system requirements
PC: ATI Radeon 9600 or later. NVIDIA GeForce FX 5200 or later. 1GB RAM.
Mac: Intel processor. Quartz Extreme graphics card (Resolume Avenue is not compatible with integrated Intel graphics processors). 1GB RAM.
interativus
Post by interativus »
I'm trying to solve the same problem...
In my case, i'm starting to suspect of a Vista incompabillity. I'm running Resolume 3.1.1 under Vista Home Premium 64 bit and my laptop config is:
HP Pavilion DV7-1285
Intel Core 2 duo P8600 @2.4ghz
6Gb Ram
GeForce 9600M GT - 512 mb dedicated memory
500gb hd
well, as you can see, it's more then necessary to run the application...
Yesterday i've upgraded my Nvidia Drivers...but still having the same problem....so, what's going on?
Sorry about my english...and thanks for your attention.
