Avenue win run error :O
js morgan
Post by js morgan »
Just installed the new version at lunchtime tried to run it and it says "This program has stoped working win is searching for a solution then shuts down the program... I still have the previous version installed 3.0.1 in its relevent directory which still runs fine. My machine is
Windows Vista 32bit
2GB RAM
intel 2 core quad 2.39
nvidia Geforce 7600 GT
creative soundblaster XFI
Hope that helps in some way to hunt down this bug... I will have a longer play later and post any relevent info cheers James M
Re: Avenue win run error :O
Please send us the log file that Avenue creates on your computer:
MAC: /Users/[username]/Library/Logs/Resolume Avenue 3 log.txt
PC: C:/Documents and Settings/[username]/Application Data/Resolume/Resolume Avenue 3 log.txt
Hopefully that will show us what is going wrong.
mail@resolume.com
consciouspilot
Post by consciouspilot »
I seem to have had this problem, until I right click and went to Run as Administrator.
Running Win 7 64 bit.
js morgan
Post by js morgan »
Sorry don't seem to have
in vista ?? searched everywhere probably beeing a bit thick :) I have tried running in admin and doesn't work as well ass runing in various compatabillity modes
js morgan
Post by js morgan »
ok found the log file in vista thanks to my mate Steve hahah
you need to unhide your files first the it is in this location
C:\Users\"your name"\AppData\Roaming\Resolume
Will send log to you cheers James M
js morgan
Post by js morgan »
Hi sorry haven't got time to trawl through but its one of the vst files causing the problem think it maybe "hi pass" I replaced it with my old vst folder and it works now :) Awesome thanks for ya time
