alphabetical file order in file browser - possible?
cannot fix this thing and cannot find the solution nowhere. do you have any idea whether it is possible at all?
						Re: alphabetical file order in file browser - possible?
i recognized, resolume sorts the decks, by the date they were created.
if you are using just 10 decks, dont mind. but if you are creating a big number of decks, you will spend a lot of time to find your decks, when you need them. the system of the old version, especially with creating folders and the ability to move decks was great. PLEASE!
i am sorry about complaining again, but i spent the last days creating decks and now avenue has made a mess while loading the startup decks. it loaded the wrong decks, some even with the wrong names.This happened after i closed all decks and restarting, to see how avenue sorts the decks in the browser. and after closing the strange decks, reloading and restarting, one deck is gone and under the old name of this deck another deck is saved twice. Fuck !
In 2.3 the answer involved the way the hard drive was formatted, I believe the problem was Fat 32.
