Resolume crashes on some AVI Files
Lynx
Post by Lynx »
Hi There,
Ik have a problem with some AVI Files in Ave 3.1.1. When I want to load the file on to a layer or when I want to preview the file, Resolume crashes.
Here is my log. The last line says: failed to open file with VFW, try use Quicktime as fallback. I've search the Resolume website and the internet and downloaded a new codec but still resolume crashes.
Thnx
Resolume Avenue 3.1.1 rev2010
Log started: 27 Oct 2009 10:27:37 pm
logging has started
Operating system: Windows Vista
OS 64 bit: No
CPU vendor: GenuineIntel
CPU speed: 1796MHz
Number of CPUs: 2
Memory size: 2048MB
system language is: nl
registration valid
hd serial valid
serial has not expired
Instantiate midi controller
Create ApplicationParameterCollection
Create ApplicationPropertyCollection
create composition state object
create video engine state object
getApplicationVFXPath: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx
create audio engine state object
getApplicationAFXPath: C:\Program Files\Resolume Avenue 3.1.1\plugins\afx
create application lookups
create file loader
start loading application settings
set language
Hello = Hello
ScreenSetup, remove diconnected displays
ScreenSetup, add newly found displays
ApplicationPropertyCollection, load contextual shortcuts from disk
ApplicationPropertyCollection, check for user configured keyboard shortcuts
ApplicationPropertyCollection, no user configured keyboard shortcuts found
ApplicationPropertyCollection, midi file path C:\Program Files\Resolume Avenue 3.1.1\default\contextualMidiShortcuts.xml
initialize quicktime
create playback controller
create composition object
create GUI
load help file
create audio/video plugin collection
create video engine
Algemeen PnP-beeldscherm NVIDIA GeForce Go 7600 {09320806-1EF8-4D73-8522-F4A3855B7AE8
new context is created
Init glew succeeded
vendor main GL renderer: NVIDIA Corporation
name main GL renderer: GeForce Go 7600/PCI/SSE2
version GL driver main renderer: 2.1.0 atof: 2.0999999
No support for GLEW_ARB_texture_non_power_of_two
nonpoweroftwo NOT supported
GLEW_EXT_framebuffer_object supported
GLEW_ARB_pixel_buffer_object supported
glCheckFramebufferStatusEXT
GL_FRAMEBUFFER_COMPLETE_EXT!
find video plugins and add them to the plugin collection
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGL3dPixels.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLAddSubtract.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLBrightnessContrast.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLColorize.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLColourPass.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLCreateAlphaChannel.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLFlip.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLFreeze.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLGradients.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLInvertRGB.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLLumaWaves.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLParticles.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLPixelHighPass.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLPointGrid.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLRotateXMixer.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLRotateYMixer.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLShiftRGB.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLSolidColor.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLStingySphere.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLThreshhold.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLTrails.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLVertexControl.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLWipeDown.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLWipeLeft.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLWipeRight.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLWipeUp.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLZoomMixer.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\AVFFGLZoomMixerOut.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLAdd.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLAdd50.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLAlpha.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLBlow.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLBlur.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLBurn.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLCircles.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLDarken.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLDifference.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLDifferenceInverse.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLDistortion.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLDodge.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLExposure.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLHardLight.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLHeat.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLHueRotate.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLKaleidoscope.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLLevels.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLLighten.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLLighten50.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLLorez.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLLumaDisplace.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLLumaIsAlpha.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLLumaKey.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLLumaKeyInverse.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLMirror.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLMultiply.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLPosterize.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLRGBASwitch.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLSaturation.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLScreen.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLSlide.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLSoftLight.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLSqueeze.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLSubtract.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLTile.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLTwirl.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\FFGLWipeRadial.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\SyzGL_Colourise.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\SyzGL_Fragment.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\SyzGL_Goo.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\SyzGL_Iterate.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\SyzGL_Kaleidoscope.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\SyzGL_RadialBlur.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\SyzGL_Ripples.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\SyzGL_Stripper.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\SyzGL_Tunnel.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\SyzGL_VideoWall.dll
load succeeded
load plugin: C:\Program Files\Resolume Avenue 3.1.1\plugins\vfx\SyzGL_Vignette.dll
load succeeded
begin Setup secondary contexts
end Setup secondary contexts
create audio engine
Adding destination (address: 212481360) to audio callback, inputPair are 0
Succesfully added destination with index
opening dsound out device: Primair geluidsstuurprogramma rate=44100 bits=16 buf=960
opening dsound out step 2
opening dsound out step 3
opening dsound in device: Primair stuurprogramma voor opnemen van geluid rate=44100 bits=16 buf=960
opening dsound in step 2
Adding source (address: 210420600) to audio callback, outputPair is 1
Succesfully added source with index
Adding source (address: 214498912) to audio callback, outputPair is -1
Changing audio setup to:
Output Device: Primair geluidsstuurprogramma
Input Device: Primair stuurprogramma voor opnemen van geluid
Samplerate: 44100
BlockSize: 960
closing dsound in: Primair stuurprogramma voor opnemen van geluid
closing dsound out: Primair geluidsstuurprogramma
Changed inputPair on destination 0 (address 212481360) to -1
find audio plugins and add them to the plugin collection
Attempting to load VST: C:\Program Files\Resolume Avenue 3.1.1\plugins\afx\vst\Resolume Bitcrusher.dll
Creating VST instance: Resolume Bitcrusher
Initialising VST: Resolume Bitcrusher
Attempting to load VST: C:\Program Files\Resolume Avenue 3.1.1\plugins\afx\vst\Resolume Distortion.dll
Creating VST instance: Resolume Distortion
Initialising VST: Resolume Distortion
Attempting to load VST: C:\Program Files\Resolume Avenue 3.1.1\plugins\afx\vst\Resolume EQ-3.dll
Creating VST instance: Resolume EQ-3
Initialising VST: Resolume EQ-3
Attempting to load VST: C:\Program Files\Resolume Avenue 3.1.1\plugins\afx\vst\Resolume Flanger.dll
Creating VST instance: Resolume Flanger
Initialising VST: Resolume Flanger
Attempting to load VST: C:\Program Files\Resolume Avenue 3.1.1\plugins\afx\vst\Resolume High-Pass.dll
Creating VST instance: Resolume High-Pass
Initialising VST: Resolume High-Pass
Attempting to load VST: C:\Program Files\Resolume Avenue 3.1.1\plugins\afx\vst\Resolume Low-Pass.dll
Creating VST instance: Resolume Low-Pass
Initialising VST: Resolume Low-Pass
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
start file loader, if autoload directories are present they will be loaded now
mainwindow, update lists
start audio engine
start render engine
begin GlEngine start
end GlEngine start
initializes the ApplicationPropertyCollection, opens up osc and
osc receive disabled
osc send disabled
start playback controller
Initialise midi controller, start devices
Startup sequence completed
Re: Resolume crashes on some AVI Files
Can you mail@resolume.com us so we can have a look at these videos?
