Video on Macbook pro won't start
DirkW
Post by DirkW »
I want to use Resolume Avenue 3.1.2 for a theater show in april next year. So I am trying to get acquainted with it. I tested it on a Mac Pro and it works perfectly. Now I am shifting towards a brand new Macbook Pro with Mac OS X 10.6.1 and I found that the video's load but don't start when clicked. Even the demo video's don't start. Only when I load them directly from the finder (presumably without the audio) they work correctly (but of course no sound). I performed a test with OpenGL extensions viewer and all test are successful except for test 3.0 (status $282.
Anybody any suggestions? Thx
Dirk Willem
ps. This is the report from the OpenGLViewer:
$357
$358
$366
$211
$382
$196
$256
$324
$257
$396
$201
$193
$165
$321
$326
$400
$322
$315
$319
$141: 111
GL_APPLE_aux_depth_stencil
GL_APPLE_client_storage
GL_APPLE_element_array
GL_APPLE_fence
GL_APPLE_float_pixels
GL_APPLE_flush_buffer_range
GL_APPLE_flush_render
GL_APPLE_object_purgeable
GL_APPLE_packed_pixels
GL_APPLE_pixel_buffer
GL_APPLE_rgb_422
GL_APPLE_specular_vector
GL_APPLE_texture_range
GL_APPLE_transform_hint
GL_APPLE_vertex_array_object
GL_APPLE_vertex_array_range
GL_APPLE_vertex_program_evaluators
GL_APPLE_ycbcr_422
GL_ARB_color_buffer_float
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_imaging
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_shader_objects
GL_ARB_shader_texture_lod
GL_ARB_shading_language_100
GL_ARB_shadow
GL_ARB_texture_border_clamp
GL_ARB_texture_compression
GL_ARB_texture_cube_map
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_non_power_of_two
GL_ARB_texture_rectangle
GL_ARB_transpose_matrix
GL_ARB_vertex_blend
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_window_pos
GL_ATI_separate_stencil
GL_ATI_texture_env_combine3
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array
GL_EXT_depth_bounds_test
GL_EXT_draw_buffers2
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_s3tc
GL_EXT_texture_env_add
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_rectangle
GL_EXT_texture_sRGB
GL_EXT_transform_feedback
GL_IBM_rasterpos_clip
GL_NV_blend_square
GL_NV_depth_clamp
GL_NV_fog_distance
GL_NV_fragment_program2
GL_NV_fragment_program_option
GL_NV_light_max_exponent
GL_NV_multisample_filter_hint
GL_NV_point_sprite
GL_NV_texgen_reflection
GL_NV_vertex_program2_option
GL_NV_vertex_program3
GL_SGIS_generate_mipmap
GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod
$192
v1.1 (100 % - 7/7)
v1.2 (100 % - 8/8)
v1.3 (100 % - 9/9)
v1.4 (100 % - 15/15)
v1.5 (100 % - 3/3)
v2.0 (100 % - 10/10)
v2.1 (100 % - 3/3)
v3.0 (65 % - 15/23)
v3.1 (12 % - 1/8)
v3.2 (11 % - 1/9)
$390
$391
$116
$114
$118
$120
$122
$128
$123
$125
$129
$132
$140
$386
$388
$310:
$385$385$385$385$385
Re: Video on Macbook pro won't start
When you set a video only clip to timeline mode instead of BPM Sync does it then play?
GeeEs
Post by GeeEs »
Not sure... but is it possible that your audio interface is not active/selected ??
Is it running when you select a videoclip without audio on "timeline" mode?
I had similar problems on my PC when I had the democlips with audio in my deck.
The clips with audio will be BPM synced by default, but the BPM is not working/running when there's no correct audiointerface selected...
In my experience: The clips try to start but there is no BPM, so they wait for the first beat... The moment you select an interface (Asio or other audiodriver) everything starts to move...
GeeEs
Post by GeeEs »
hehehe.. You sneaked in between Bart ;)
DirkW
Post by DirkW »
When the clip is set to timeline and I click on it the first frame is shown in the composite (so there is a change) but it still won't play. On BPMsync I just get a yellow bar. It looks like its waiting indeed for sound sync. Are there any audio settings I need to adjust?
Indeed the videos withouth audio are working correct.
On the Audio tab of the Preferences you can double check if a sound card is selected.
DirkW
Post by DirkW »
That did the trick! Thx!
