Hello guys, great job on the Flash implementation! Now that it's taken care of, i'm hoping you can resolve a problem I have been having since I bought resolume.
I work with live musicians, and I feed the live video into Resolume. As long as the camera is on BEFORE i start resolume, it sees it fine, and I can set up multiple clips with different clip settings and effects.
The problem is that if i close resolume, and then start up the composition with the camera off ALL OF THE CLIPS DISAPPEAR. This makes it very difficult for me to set up the multiple live clips that I need, because I would have to have a video camera on EVERY time I want to work on that composition.
Someone suggested that I set up dummy clips and then replace them with the live video, but that does not work for me because the clip settings are all reset even though the effects remain.
Is this problem on your to-do list?
Live video feed
Live video feed
Laptop: Intel Core 2cpu T7200 @2Ghz - 2Gig Ram
Operating system: Windows Vista Ultimate Sp1 X64
Video card: NVIDIA Gforce Go 7600
Re: Live video feed
hello, i am now interested in live video feed in resolume, however i couldnt find how to do it.
For your problem, i thought did you try to make two decks; one is only for live video feed and the other is other clips, does it work?
I have firewire cable in to the computer but no video, how can i see live video feed in resolume? which button?
do i need to have video cam is on to see and choose what is....
thank you for your help. best, burcu
Re: Live video feed
Hey Burcu
The video inputs can be found under the Sources tab in the bottom right.
Regarding the video camera clips disappearing, this problem should be fixed, and the latest versions will show a dummy clip when the camera is not connected.
