All VFX Presets Lost
craftycurate
Post by craftycurate »
Has anyone else found this? All my VFX presets have been erased, perhaps by a more recent installation of R3 (probalby a test beta).
Could installations either leave the XML files alone, or create backup copies if it needs to create a new version?
Richard
Re: All VFX Presets Lost
hmm i,ll do some more testing on this, the instrallers should not overwrite the presets. are u using mac or pc?
craftycurate
XP Pro SP3 ...
Was able to recover my presets from an old backup.
Cheers
Richard
vjloco
Post by vjloco »
Yeah, I aked this question weeks ago and got no answer. I am really glad you were able to retrieve your settings. I had no idea that I risked losing all of these presets, and did not back them up. Plus, on windows, they are hidden deep in a folder, with no indication from Resolume that they should be backed up.
Laptop: Intel Core 2cpu T7200 @2Ghz - 2Gig Ram
Operating system: Windows Vista Ultimate Sp1 X64
Video card: NVIDIA Gforce Go 7600
craftycurate wrote:Has anyone else found this? All my VFX presets have been erased, perhaps by a more recent installation of R3 (probalby a test beta).
I'm trying to reproduce this but found that the installer nor Resolume overwrites any effetct preset files.
Did you perhaps un-install resolume before installing a newer version?
Un-installing Resolume will indeed remove all presets.
vjloco
Post by vjloco »
I did not uninstall Resolume, but lost many, but not all the presets.
Could you all zip the folder with the presets, email it to us and let us know which presets have been lost? Perhaps the preset files are still there but is the xml corrupted.
MAC: /Users/[username]/Library/Application Support/Resolume Avenue 3/presets/vfx/
PC: /Documents and Settings/[username]/Application Data/Resolume Avenue 3/presets/vfx/
Email it to support@resolume.com
craftycurate
From memory I tend to install the new version first, and then remove older versions.
hmm yeah that would remove the presets eventhough you want to keep them, I,ll fix this.
craftycurate
I have recently restored the presets from a backup, so I don't have the newer ones to hand.
