Velocity control
fongaboo
Velocity control
Post by fongaboo »
Is there a way to map MIDI velocity control to, say... Opacity and/or Volume?
If there is initially someway to map it to a dashboard knob, then I suppose a knob with both opacity and volume would do the trick...
Re: Velocity control
Yes you can use the velocity of a midi note, just map the midi note to the parameter you want to control and enable Velocity in the midi mapping panel that appears in place of the preview monitor.
Screen shot 2009-11-24 at 13.13.43.png (17.31 KiB) Viewed 4126 times
