There is only local footage speed as I can see, but, I have no enough routers to control all 30 clips speed...
Layer speed in Resolume 3
Hi guys,I want to ask you, is it possible to manage(and map for MIDI) the layer speed parameter in Resolume 3? Some kind of global speed in other words.
Re: Layer speed in Resolume 3
Hey Doomss
There is no speed control at the composition level, or global speed as you call it. One way to control the speed of clips with one control, is to switch the Application Midi mapping mode to deck, and then assign the same rotary knob to the speed control of all the clips. You can also choose to assign the clips that will trigger in the same layer the same controller, and a different one for the clips that will trigger in another layer. That ways you'll have control over the individual clips playing at that time.
I hope that makes sense, and gives you the control you're looking for.
to answer your question, there is currently no way (to the best of my knowledge) to assign midi to the layer transport controls. it's on my wishlist as well... but, you can assign a control to the currently active clip's speed control. this way, you can choose the layer whose clip you want to control. it's what i'm using right now... you can still only control one clip's speed at a time, but it's better than assigning controls for all clips individually, imo.
to do this, use "Application MIDI Mapping" in Layer mode.
And on our to-do list toodep wrote:it's on my wishlist as well...
Nooooo... It's the first think i wished from the first release....pleeeeeeeeeeeeeeeeeeease guys, make me happy... it's so important for a live act!
HopeHopeHopeHopeHopeHopeHopeHopeHope
one way to control global speed is to have all clips synced to BPM, even if your not beat matched to the music. you turn down the bpm all clips slow down and vice versa. maybe not an ideal solution if you prefer working in time line mode, just though I would throw it out there as a work around solution.
oh, I almost forgot, GeeEs seems to have found a trick to get layer transport mapping to work, even for layer speed. You have to have an active clip in the layer, and make sure you can see the layer transport controls (select in view menu). you can map a midi control to speed/pitch.dep wrote: there is currently no way (to the best of my knowledge) to assign midi to the layer transport controls.
see more info here:
viewtopic.php?f=13&t=5902&start=0#p22341
This should be implemented by now or am I missing something.
Coming from other vj platforms, this is my most needed tool to VJ properly. Changing the speed of each video layer. It's impossible to do now, since I change my clips all the time.
Drop the clip speed connection and add the layer speed ability. So I can use my Midi tools the way I am used to.
My style is mixing fast and slow videos, not the master play speed.
HOPEHOPEHOPEHOPEHOPE to be added soon
Go to the View menu -> Make sure View Layer Transport Controls is checked.
Now you can control the speed of each clip in each layer on the top left side of the interface. Also you can map each of these to midi.
Should have gotten that by myself, thanks tho!
