Hi there. I have Resolume running on Windows 7, and it loads .avi files fine. But if i try to drag .mov files into resolumes it just do nothing. No error, nothing.
I've already tried the following:
installed dxv codec manually
installed the K-Lite codec Pack
copy qtSystem file from Windows XP to windows 7
updated the graphic card driver (GeForce 9800 Gt)
Any suggestions? thx!
Avenue 3 on Windows 7 can't load quicktime mov files
dexter_deluxe
dexter_deluxe
Re: Avenue 3 on Windows 7 can't load quicktime mov files
solved: just installed the quicktime player for windows 7... strange, though windows 7 supports quicktime natively... but yeah, it works now!
VJ IQ-VISUALS
This help is the best i ever read !!!!!!!! Thanx to Digital-snot
1. open a command prompt with administrator privileges.
A. if your login already has administrator privileges, simply open a command prompt using (Start -> Run -> type cmd -> [ENTER])
B. If you have Command Prompt on your Start menu, just right-click and choose Run as administrator. If not, open Windows Explorer, navigate to C:\Windows\System32 and find cmd.exe - right-click and choose Run as administrator.
C. go to "start search" in the windows start menu.
type: cmd
cmd icon will show up, right-click and choose Run as administrator.
2. execute the following command:
regsvr32 ir50_32.dll
(to execute a command, type the above line out EXACTLY -including the space and the underscore- and hit "Enter" )
restart your computer.digital:snot
Senior Member
THANX DIGITAL-SNOT
type: cmd
Senior Member
THANX DIGITAL-SNOT
