Quicktime Files Are Loading at a Smaller Size
thirdivan
Post by thirdivan »
My Quicktime files are loading into Resolume at smaller size than my avi's. Does anybody have a fix for this or batch encoding the answer.
oblivionrpg
Re: Quicktime Files Are Loading at a Smaller Size
Post by oblivionrpg »
I dont want to start a new thread, bcs I think this is the same question as I have, I am used to having all my videos automatically stretched to the comp size from Res 2.41. Can this option be activated in Avenue somehow? Thanx.
thirdivan wrote:My Quicktime files are loading into Resolume at smaller size than my avi's. Does anybody have a fix for this or batch encoding the answer.
Please send one of your files to mail@resolume.com we'd like to have a looksy.
oblivionrpg wrote:I dont want to start a new thread, bcs I think this is the same question as I have, I am used to having all my videos automatically stretched to the comp size from Res 2.41. Can this option be activated in Avenue somehow? Thanx.
On the Layer Properties panel you can enable the layer width and height. When you do this all clips that will be played in that layer will be adjusted to that layer size.
Do this for all layers and all your clips will come out scaled correctly.
oblivionrpg
Thank you!!
