I have partitioned the principal HHD (WD Raptor) and installed Windows 7-32 bit.
After the installation of the OS, I have installed (in this order):
- Driver Motherboard (automatically downloaded)
- Driver Video Card
- Driver Sound Card
- MidiYoke
- Mozilla Firefox 3.5
- Apple Quicktime 7
- Adobe Flash CS4 (without the installation of the complete software, Resolume 3 don't read my SWF files. It seems that the Flashplayer is not enough)
- Driver Korg + Editor Korg
- Bome's Midi Translator
Unfortunately after a few hours of use (4-5) also Resolume 3, as the 2.41 on XP, gradually begin to "forget" the midi maps and the effects setting; and maintains an average of crash of around 1 every 2 hours (that for a Windows user isn't much
It seems that, as the VJ, also the software feels the tiredness after many hours of nonstop use...
I think that it can depend on some setting of the OS and I would like to know what is the better way to set Windows 7 to maintain the most stable possible Resolume 3.
For example, what services it is better to disable; if it is better to disable the Windows Defender or the Windows indexing files, etc. etc. ...
Thanks in advance
-Efrem-
