DXV and Converters
Tschoepler
DXV and Converters
Post by Tschoepler »
Hey guys,
I was wondering if it was possible to implement the DXV codec in freeware such as MediaCoder (http://www.mediacoderhq.com). My problem is I haven't found a way to batch convert via Quicktime. Using Adobe Media Encoder = :lol: And firing up After Effects or Premiere seems to be a bit overdosed to me ;) How do you convert numerous files to DXV?
best,
j
VJair
Re: DXV and Converters
Post by VJair »
i batch convert in after effects. the DXV codec should be available in any software thats being used on a machine with DXV installed.
Tschoepler
VJair wrote:i batch convert in after effects. the DXV codec should be available in any software thats being used on a machine with DXV installed.
ok_that's what I did so far. Guess I'll have to stick with that.
DVX codec is not available in any software_unfortunately. mediacoder, vlc, ffe, win media player :lol: . vlc for example shows me all the quicktime codecs except DVX.
maybe I need to get deeper into the ffmpeg console...
nellacameraverde
Post by nellacameraverde »
Is there any list of DXV-compatible video converter softwares?
I've experienced problems using DXV under Adobe Premiere CS4 (Adobe Media Encoder), posted here:
http://www.resolume.com/forum/viewtopic ... 321#p24049
and I'd like to test with something different but, as Tschoepler said, many free softwares seem not to support it...
willcopps
Post by willcopps »
VJair-I'm thinking of getting After Effects, and part of the reason would be DMX conversion. Do you know if it imports WMVs?
rxfromparis
Post by rxfromparis »
i using a non free encoding program called procoder3 from grass valley
http://www.grassvalley.com/products/procoder_3
works great, batch processing
but not free :roll:
does not work on my 64 bits machine :cry:
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000 :))
willcopps
Post by willcopps »
Thanks RX!
Tschoepler
rxfromparis wrote:i using a non free encoding program called procoder3 from grass valley
but not free :roll:
Definitely (one of) the best commercial coder around for years. +1
sleepytom
Post by sleepytom »
Mpeg stream clip supports DXV encooding so long as you use real quicktime not quitime alternative. http://www.squared5.com/
QTAmateur for MacOS X is old but simple and free:
http://www.mikeash.com/software/qtamateur/
