best netbook for resolume
epiq
Post by epiq »
:?: Hello!
Can any suggest me best netbook for resolume? I think about 13"-14" size and 2-2.3kg weight with budget ~750$.
I found some models:
Acer Aspire Timeline 3810TG-733G25i
(Core 2 Duo SU7300 1300 Mhz/13.3"/1366x768/3072Mb/250.0Gb/DVD нет/Wi-Fi/WiMAX/Win 7 HP)
or
ASUS K40IJ
(Pentium Dual-Core T4300 2100 Mhz/14.0"/1366x768/3072Mb/320.0Gb/DVD-RW/Wi-Fi/WiMAX/Win 7 HB)
or may be anybody tell me much better variants ?
thanx for yous attention
epiq
VJair
Re: best netbook for resolume
Post by VJair »
what graphics cards do they have?
epiq
Post by epiq »
acer have ATI Mobility Radeon HD4330 512 Мб GDDR3
asus have Intel GMA 4500MHD SMA
epiq
Post by epiq »
also i want in future change native hdd to ssd version for better performance, or use e-Sata ssd
HerrNieDa
Post by HerrNieDa »
i have an eye on this one!
http://h10010.www1.hp.com/wwpc/de/de/ho ... 07118.html
has still shared memory, but should be faster than a normal new macbook (ok, the cpu is not equal, but for avenue performance with dxv, my proceccors are really bored normally ;)
and it has multitouch :P
VJair
Post by VJair »
the acer will perform pretty badly with avenue because of the graphics card
the asus wont work with avenue because of the graphics card.
avoid both of them.
VJair
Post by VJair »
HerrNieDa wrote:i have an eye on this one!
i got a dell vostro 1720 recently, its faster, has a better graphics card and is cheaper than that hp. you are making a lot of trade offs for multi touch there.
VJair
Post by VJair »
for avenue,especiay if you want to take advantage of the DXV codec and FFGL's, the GPU is a key part. this site compares GPUs and provides benchmark scores http://www.notebookcheck.net/Mobile-Gra ... 844.0.html
epiq
Post by epiq »
ok, which graphics card from middle-cost segment is best choice for avenue?
i search for models in ~700-900$ diapason
epiq
Post by epiq »
In my price range i search 2 models from http://www.notebookcheck.net/Mobile-Gra ... 844.0.html list with Mobility Radeon HD 5650:
Packard Bell EasyNote LJ75 (Core i3 / Core i5, 2130-2260 МГц, Wi-Fi, 3.4 кг, 4096 Мб, 320-500 Гб, 17.3 дюйм, DVD-RW)
and
Sony VAIO VPC-EB1M1R (Core i3 330M 2130 Mhz/15.5"/1366x768/4096Mb/320.0Gb/DVD-RW/Wi-Fi/Bluetooth/Win 7 HB)
Mobility Radeon HD 5650 is only 40th in http://www.notebookcheck.net/Mobile-Gra ... 844.0.html list , but it's price is avalaible for me now ;)
What are you think about it?
