Avenue 3.1.3 crashes when entering key/midi Mapping
klaus.meier
Post by klaus.meier »
Hello,
I have Av. 3.1.3 on XP SP2.
Whenever I tried to enter key or midi mapping Resolume crashes.
Removing all Resolume folders in Documents and Settings did not help (found this idea in a posting here).
It happened with or without connected midi device (Behringer BCR2000).
It happened with or without using the BCR device enabled in preferences.
Here is the Log:
Resolume Avenue 3.1.3 rev2288
Log started: 20 Mar 2010 10:29:10 am
logging has started
Operating system: Windows XP
OS 64 bit: No
CPU vendor: GenuineIntel
CPU speed: 1642MHz
Number of CPUs: 2
Memory size: 2048MB
system language is: de
registration valid
hd serial valid
serial has not expired
Instantiate midi controller
Create ApplicationParameterCollection
Create ApplicationPropertyCollection
create composition state object
create video engine state object
getApplicationVFXPath: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx
create audio engine state object
getApplicationAFXPath: d:\Programme\Resolume Avenue 3.1.3\plugins\afx
create application lookups
create file loader
start loading application settings
set language
Hello = Hello
ScreenSetup, remove diconnected displays
ScreenSetup, add newly found displays
ApplicationPropertyCollection, load contextual shortcuts from disk
ApplicationPropertyCollection, check for user configured keyboard shortcuts
ApplicationPropertyCollection, no user configured keyboard shortcuts found
ApplicationPropertyCollection, midi file path d:\Programme\Resolume Avenue 3.1.3\default\contextualMidiShortcuts.xml
initialize quicktime
create playback controller
create composition object
create GUI
load help file
create audio/video plugin collection
create video engine
Plug und Play-Monitor NVIDIA GeForce Go 7900 GS {B194DAEE-1480-474E-AC2D-59D4B2C86692
new context is created
Init glew succeeded
---Info main OpenGL renderer---
Vendor : NVIDIA Corporation
Model: GeForce Go 7900 GS/PCI/SSE2
OpenGL version: 2.1.1
OpenGL version short: 2.1
GLEW_EXT_framebuffer_object supported
framebuffer_object enabled
GLEW_ARB_texture_non_power_of_two supported
texture_non_power_of_two enabled
GLEW_ARB_pixel_buffer_object supported
pixel_buffer_object disabled
glCheckFramebufferStatusEXT
GL_FRAMEBUFFER_COMPLETE_EXT!
find video plugins and add them to the plugin collection
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGL3dPixels.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLAddSubtract.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLBrightnessContrast.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLColorize.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLColourPass.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLCreateAlphaChannel.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLCubeTiles.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLFlip.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLFreeze.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLGradients.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLInvertRGB.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLLumaWaves.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLMask50.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLParticles.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLPixelHighPass.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLPointGrid.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLRotateXMixer.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLRotateYMixer.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLShiftRGB.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLSolidColor.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLStingySphere.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLThreshhold.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLTimeSwitcher.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLTrails.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLVertexControl.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLVertexControlCrop.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLVertexControlMask.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLWipeDown.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLWipeLeft.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLWipeRight.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLWipeUp.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLZoomingCubes.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLZoomMixer.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\AVFFGLZoomMixerOut.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLAdd.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLAdd50.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLAlpha.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLBarshift.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLBlow.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLBlur.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLBurn.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLCircles.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLDarken.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLDifference.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLDifferenceInverse.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLDistortion.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLDodge.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLExposure.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLHardLight.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLHeat.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLHueRotate.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLKaleidoscope.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLLevels.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLLighten.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLLighten50.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLLorez.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLLumaDisplace.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLLumaIsAlpha.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLLumaKey.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLLumaKeyInverse.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLMirror.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLMultiply.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLPosterize.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLRGBASwitch.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLSaturation.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLScreen.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLSlide.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLSoftLight.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLSqueeze.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLStatic-source.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLStatic.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLStopMotion.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLStroboscope-effect.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLStroboscope.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLSubtract.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLTile.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLTwirl.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FFGLWipeRadial.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\FreeImage.dll
load failed
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\SyzGL_Colourise.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\SyzGL_Fragment.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\SyzGL_Goo.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\SyzGL_Iterate.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\SyzGL_Kaleidoscope.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\SyzGL_RadialBlur.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\SyzGL_Ripples.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\SyzGL_Stripper.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\SyzGL_Tunnel.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\SyzGL_VideoWall.dll
load succeeded
load plugin: d:\Programme\Resolume Avenue 3.1.3\plugins\vfx\SyzGL_Vignette.dll
load succeeded
begin Setup secondary contexts
end Setup secondary contexts
create audio engine
opening dsound out device: Primärer Soundtreiber rate=44100 bits=16 buf=960
opening dsound out step 2
opening dsound out step 3
opening dsound in device: Primärer Soundaufnahmetreiber rate=44100 bits=16 buf=960
opening dsound in step 2
find audio plugins and add them to the plugin collection
Attempting to load VST: d:\Programme\Resolume Avenue 3.1.3\plugins\afx\vst\Resolume Bitcrusher.dll
Creating VST instance: Resolume Bitcrusher
Initialising VST: Resolume Bitcrusher
Attempting to load VST: d:\Programme\Resolume Avenue 3.1.3\plugins\afx\vst\Resolume Distortion.dll
Creating VST instance: Resolume Distortion
Initialising VST: Resolume Distortion
Attempting to load VST: d:\Programme\Resolume Avenue 3.1.3\plugins\afx\vst\Resolume EQ-3.dll
Creating VST instance: Resolume EQ-3
Initialising VST: Resolume EQ-3
Attempting to load VST: d:\Programme\Resolume Avenue 3.1.3\plugins\afx\vst\Resolume Flanger.dll
Creating VST instance: Resolume Flanger
Initialising VST: Resolume Flanger
Attempting to load VST: d:\Programme\Resolume Avenue 3.1.3\plugins\afx\vst\Resolume High-Pass.dll
Creating VST instance: Resolume High-Pass
Initialising VST: Resolume High-Pass
Attempting to load VST: d:\Programme\Resolume Avenue 3.1.3\plugins\afx\vst\Resolume Low-Pass.dll
Creating VST instance: Resolume Low-Pass
Initialising VST: Resolume Low-Pass
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
start file loader, if autoload directories are present they will be loaded now
mainwindow, update lists
start audio engine
start render engine
begin GlEngine start
end GlEngine start
initializes the ApplicationPropertyCollection
OSC receive disabled
OSC send disabled
start playback controller
Initialise midi controller, start devices
Startup sequence completed
failed to open file with VFW, try use Quicktime as fallback.
context is deleted previewCanvas
The last entry makes me a little nervous...
Anyway, are there any recommendations or solutions?
Thank you :)
Klaus
Re: Avenue 3.1.3 crashes when entering key/midi Mapping
Have you tried reloading the original Midi map? This can be done via the Midi tab of the preferences menu.
Hope that helps.
klaus.meier
Thank you for your answer.
Yes - I tried to load the default map.
But it did not help.
Resolume crashes as described above.
Is this a know bug?
What else can I do, or assist you to fix this?
Grreetings
Ah yes, now that I check the logfile again I see you reset everything to default and deleted any user made maps. Sorry about that!
We haven't come across this bug before, and I'll add it to the to-do list. In the meantime, did the mapping work for you in the past? If so, could you maybe think of anything that has changed (like in your system setup) which would possibly affect this issue?
klaus.meier
Hey Joris,
mapping never worked.
I have 1800 x 1200 Screen resolution.
Whenever entering the mappingmode (either midi or key) - Resolume goes away.
Changing the screen resolution results in a different behavior.
in 1280 x 800, Resolume crashes when leaving the mapping mode.
It also occures on a completely new installed XP with the new 3.2 Version.
Do you need an Acronis Image (only usefull if you have the Dell inspiron 9400)...
Any additional advice is very appreciated.
This is really strange, with verison 3.2 can you please use the Feedback form in the Preferences to send us the log file? We'd like to have a look at that.
klaus.meier
Hey Bart,
and here ist is (not very proud to present)
Resolume Avenue 3.2.0 rev2600
Log started: 10 May 2010 10:40:35 pm
logging has started
OS 64 bit: No
CPU speed: 1706MHz
Number of CPUs: 2
Memory size: 2047MB
registration invalid
hd serial invalid
Instantiate OSC state
getApplicationVFXPath: c:\Programme\Resolume Avenue 3.2.0\plugins\vfx
getApplicationAFXPath: c:\Programme\Resolume Avenue 3.2.0\plugins\afx
create file loader
set language
Hello = Hello
ApplicationPropertyCollection, midi file path c:\Programme\Resolume Avenue 3.2.0\default\contextualMidiShortcuts.xml
Quicktime could not be intialized, is it installed?
create GUI
load help file
create video engine
Plug und Play-Monitor NVIDIA GeForce Go 7900 GS {0A1B5AB9-FD4C-4CB1-9196-CA75BF709B1E
Init glew succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGL3dPixels.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLAddSubtract.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLBrightnessContrast.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLColorize.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLColourPass.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLCreateAlphaChannel.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLCubeMixer.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLCubeTiles.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLFeedback.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLFlip.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLFreeze.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLGradients.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLInvertRGB.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLLumaWaves.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLMask50.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLParticles.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLPixelHighPass.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLPointGrid.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLRotateXMixer.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLRotateYMixer.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLShiftRGB.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLSnow.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLSolidColor.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLStingySphere.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLThreshhold.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLTimeSwitcher.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLTrails.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLVertexControl.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLVertexControlCrop.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLVertexControlMask.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLWipeDown.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLWipeLeft.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLWipeRight.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLWipeUp.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLZoomMixer.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\AVFFGLZoomMixerOut.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLAdd.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLAdd50.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLAlpha.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLBarshift.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLBlow.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLBlur.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLBurn.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLCircles.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLDarken.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLDifference.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLDifferenceInverse.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLDistortion.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLDodge.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLEdgeDetection.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLExposure.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLFishEye.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLHardLight.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLHeat.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLHueRotate.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLKaleidoscope.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLLevels.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLLighten.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLLighten50.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLLorez.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLLumaDisplace.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLLumaIsAlpha.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLLumaKey.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLLumaKeyInverse.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLMirror.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLMultiply.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLPosterize.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLPremultiplier.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLRGBASwitch.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLSaturation.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLScreen.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLSetMask.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLSlide.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLSoftLight.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLSqueeze.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLStatic-source.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLStatic.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLStopMotion.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLStroboscope-effect.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLStroboscope.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLSubtract.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLTile.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLTwirl.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLWaveWarp.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\FFGLWipeRadial.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\SyzGL_Colourise.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\SyzGL_Fragment.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\SyzGL_Goo.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\SyzGL_Iterate.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\SyzGL_Kaleidoscope.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\SyzGL_RadialBlur.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\SyzGL_Ripples.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\SyzGL_Stripper.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\SyzGL_Tunnel.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\SyzGL_VideoWall.dll
load succeeded
load plugin: C:\Programme\Resolume Avenue 3.2.0\plugins\vfx\SyzGL_Vignette.dll
load succeeded
create audio engine
Attempting to load VST: C:\Programme\Resolume Avenue 3.2.0\plugins\afx\Resolume Bitcrusher.dll
Attempting to load VST: C:\Programme\Resolume Avenue 3.2.0\plugins\afx\Resolume Distortion.dll
Attempting to load VST: C:\Programme\Resolume Avenue 3.2.0\plugins\afx\Resolume EQ-3.dll
Attempting to load VST: C:\Programme\Resolume Avenue 3.2.0\plugins\afx\Resolume Flanger.dll
Attempting to load VST: C:\Programme\Resolume Avenue 3.2.0\plugins\afx\Resolume High-Pass.dll
Attempting to load VST: C:\Programme\Resolume Avenue 3.2.0\plugins\afx\Resolume Low-Pass.dll
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
start audio engine
start render engine
end GlEngine start
OSC send disabled
Unfortunately the log file does not show what could be going wrong. I'm sorry this bug is very difficult for us to fix because we can not reproduce it ;-(
Let us know if you're ever in the netherlands, we'd like to debug it on your computer and see what is going wrong.
klaus.meier
You haved a Dell Inspiron9400 around?
If so, I will send you the HardDisc or a HD-Image.
