MIDI mapping: create note shortcut
Rene
Post by Rene »
How can I manually change/add a MIDI note e.g. C3 to D4? - I can change CCs manually, but not notes. Do I miss simething or is it just not possible?
Re: MIDI mapping: create note shortcut
Yeah it's not possible to manually change the midi note value. You,ll need to use MIDI learn to remap it.
Rene
Post by Rene »
Really? - Are there plans to add this in future?
gpvillamil
Post by gpvillamil »
Hmm, if there were a little documentation on how the MIDI prefs are stored in the XML file, it might be straightforward to make an editor program for MIDI assignment.
pw144
Post by pw144 »
The guy using Ableton who I'm attempting to keep up with needs me to change all my Midi triggers to Channel 1.
There doesn't appear to be the relevant pull-down to alter the mapping.
Is there a particular bit of the XML I'm looking for? Pretty hard to decipher.
Or is there a fancy editor I can use on the file?
