Triplehead2Go / Advanced Output settings help please
vide0junki3
Post by vide0junki3 »
hey, am looking to do a 2/3 projector setup using flat shape surfaces and employing projection mapping using layer masks ....
my question is - can someone who does this, or uses th2go please post a screenshot of how their advanced settings looks when the th2go is plugged in and working?
I cant get my head around how the matrox adaptor will affect my resolume compositions ... will i just have to resize my comp to 3x as long (and render my clips as such) ?
or will each projector display the same thing?
very confused over here, any help is much reccommended . if anyone can post screenshots of the settings panel with th2go or dh2go - that would probably help me get my head round it too :)
Re: Triplehead2Go / Advanced Output settings help please
If you are using the th2go you should not use the advanced output settings. With the th2go you just create a composition that is twice or three times the width, position your layers left and right. Send the output to your 2nd display (or the one that has the th2go connected) and you're set.
vide0junki3
ok thanks so much! will buy a matrox this weekend and report back!
ukg
Post by ukg »
Can I stretch the image vertically using 2 or 3 projectors and matrox Triplehead2Go ?
