OSC from QC to Resolume
sleepytom
Post by sleepytom »
I'm trying to get resolume to respond to OSC sent from Quartz Comps - i'm having no luck with it, though i've been able to get resolume to respond to issadora sending osc.
can anyone tell me which settings i need to make in QC to get resolume to hear the osc?
Re: OSC from QC to Resolume
Does it not work when you play the patch in Resolume? Or does it never work, even from QC itself?
sleepytom
Post by sleepytom »
just from QC at the moment, can't get that first step working :(
sleepytom
Post by sleepytom »
got it working - not sure what the problem was - probably data types or bundles setting i think.
sending to resolume from QC patches running in resolume works fine so stage 1 of sleepytoms pisspoor column sequencer is go :)
sleepytom
Post by sleepytom »
I've attached a zip of this comp if anyone wants to try it. It lets you sequence column triggering in resolume, providing a functionality somewhat akin to end actions in abelton live.
let me know how you get on with it.
ST-resolume_seq.zip
(16.3 KiB) Downloaded 1162 times
newfuturenow
Post by newfuturenow »
Hey SleepyTom
Trying to get your avenue sequencer working for a small project I have in mind. I am having trouble with it. I have OSC enabled in preferences, Your read me says set the input slider to BPM sync. Its probably totally obvious but I am having difficulty finding this. In the sleepytomcolumsequencer clip properties I have set the transport to BPM sync and the trigger to BPM sync, I have set the track index but still no stepping . . any ideas what I might be doing wrong?
