Select and edit several clips at a time
gavspav
Post by gavspav »
As I now have a sore finger I am making the following feature request:
The ability to be able to select more than one clip at a time - shift click? - and drag the group around decks/layers.
Also to be able to change settings such as Beatsnap/triggerstyle etc for all of the group.
Possible you can already do this and I haven't spotted it?
VJair
Re: Select and edit several clips at a time
Post by VJair »
yeah, multi clip dragging would be a great feature.
VJsynC
Post by VJsynC »
Yep, agree, and let me just add something, when you select a layer (with a clip in it) in the clip proprieties he doesn't give you that clip proprieties unless the deck in witch that clip is original from is loaded.
It would be very very useful if by selecting the layer he could give you instantly the proprieties in the clip proprieties in that layer without having to had the original deck witch that clip is originally from selected or focused.
sleepytom
Post by sleepytom »
it would also be very nice to be able to copy / paste clip attributes / fx between clips.
rxfromparis
Post by rxfromparis »
+1 !! :D
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000 :))
Yes, this would be a big time and wrist saver. It's added to the list.
Our resident Max guru gpvillamil has a patch for this: viewtopic.php?f=13&t=5825
Indeed. We are working on this, and actually had it as part of the 3.2 beta release. It then still proved too buggy to implement as part of the official release.
You can already alt-drag effects between clip, where all the attributes are retained. Or do you mean copy-paste specifically?
VJair
Post by VJair »
goto10 wrote: You can already alt-drag effects between clip, where all the attributes are retained. Or do you mean copy-paste specifically?
i didnt realise this. nice :)
sleepytom
Post by sleepytom »
cool - that's rather handy.
though actual copy paste to multiple target clips would be better for me as the process of drag and dropping an effect onto several clips is still a bit RSI inducing, not to mention the possibility of missing clips..
Tschoepler
Post by Tschoepler »
+1 for the shortcut. long live ctrl+c > ctrl+v :D
if I would want to copy attributes to more than one clip I had to remain dragging and dropping, dragging and dropping. with the attributes in memory I could easily select the next clip ctrl+v, next clip, ctrl+v. Or even multi-select clips and ctrl+v :shock:
