clip properties preset and controlers
werlin
Post by werlin »
hi, i've read around about the idea of having a clip properties preset system...
if it becomes part of resolume, would the presets be accessed via transports controls ? (sorry for being a nut about having everything on those :mrgreen: )
if not would it be possible in the future to implement some kind of nav system to access the clip properties ?
for example, using the apc40 useless bank select buttons, or the keyboards arrow keys, to navigate through clip properties ? (much like ableton bank select)
i ask this because, correct me if im wrong, i think its not possible to have a kind of shift key when it comes to midi, and there's only so many buttons you can map... although as im writing this im realizing my own stupidity because apc's do use a shift button, and perhaps that could be in fact implemented alongside the midi-feedback...
anyway could you shed some light on how accessing the clips presets would work in the future?
Re: clip properties preset and controlers
Once we get our own heads around how to go about it, of course we'll be happy to share and hear your thoughts on it, yeah! ;)
werlin
Post by werlin »
on presets or midifeedback or both?
in any case, glad to hear it
