Pixels in Space-Effect works strange
baustellen
Post by baustellen »
Hey folks!
Ive got a problem with the "pixels in space effect". i want 6 fields which each show the clip in the same way.
the problem is, the pixels having a different brightness and are flickering.
ive recorded a small clip to show you what i mean
http://www.youtube.com/watch?v=bw5geAUh ... tube_gdata
the 6fields are good, but there not equal...
heres a screenshot of my setting. ive got only a random clip and the effect.
maybe i am dreaming, but some time ago i had exactly what i wanted with that effect, but its not working out for me anymore.
please help me :(
Bildschirmfoto 2010-07-23 um 01.33.30.png (516.55 KiB) Viewed 4592 times
Re: Pixels in Space-Effect works strange
Thanks for the screenshot and the video! It really helped to recreate your setup.
The thing with the Pixels in Space effect is is it uses the brightness of the pixels to display and/or extrude them. So if the pixels of the original video are black, the Pixels in Space effect won't display anything in that area. This is causing your 6 'screens' to flicker.
If you want an effect like this without flickering, maybe try the Videowall effect?
Hope that answers your question!
baustellen
Thanks for the fast and good answer! The videowalleffect solved my problem perfectly.
But the pixels-in-space-effect is still working differently in different times, sometimes the pixel flicker, somethimes not.
