just another version 2 suggestion
ether_
Post by ether_ »
Hi guys
what would be quite useful would be a button/slider to move the in/out points simultaneously - that way if you set in/out points so the clip "loops to the beat", by sliding the in/out points you keep the same duration for the clip
...i hope that makes sense
ether
warpTV
sounds good to me ... maybe if you hold down [SHIFT] and drag the in- or out-point they will simultaneously?
