Hi
I have (the demo) of Resolume 3.2.0. I have several DXV videos without sound, but in Resolume it appears they have sound (but always the same sound graphic) and they are standard BPM controlled.
It's converted with Adobe Media Encoder CS4.
Is there a way to make them standard timeline controlled? (i hate the BPM delay)
						Resolume 3.2.0 DXV codec without sound always BPM controlled
				alfaleader
Re: Resolume 3.2.0 DXV codec without sound always BPM controlled
Hey Alfaleader
It is possible that you exported with an empty audio track. Unchecking the export audio option in Media Encoder should solve this.
Another couple of things you may or not be aware of:
1. You can set clips to be timeline controlled in the clip properties panel, which will be saved and remembered in the composition. But newly imported clips will always default to BPM sync when they have an audio track.
2. You can get rid of the delay/quantization by choosing Composition -> Beat Snap -> None
Hope that helps!
Hope that helps!
I ran into same problem (which sometimes occurs still even without sound but then mostly the clip is corrupted in some wy...) but what I discovered ... the lack of control of speed - is this wanted? it's only pitchable - but you should really make it possible to play those clips faster (or dunno ... but I kinda needed faster playback for some clips which wasn't possible)
