lock clip feature
megawattmedia
lock clip feature
Post by megawattmedia »
Also a lock clip settings function would be handy for if you've set a clip up a certain way so you can't accidently change a setting.see attached photoshop mock....
Resolume avenue lock clip2.jpg (299.99 KiB) Viewed 7105 times
Tschoepler
Re: lock clip feature
Post by Tschoepler »
+1 good idea
rxfromparis
Post by rxfromparis »
yeah +1 ;)
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000 :))
There is already a lock feature for column triggering in the works, but this is a different lock feature. Request noted and ticket made ;-)
megawattmedia
excellent it's great that users input is actually noted, when will the next updates be released?
thanks!
