Free Multi-screen keystone plugIn!!
mfo
Post by mfo »
Ivan Ryaboff from IRWorkshops was so kind to write a FFGL plugIn for dualhead/triplehead keystone correction!
And its even free!
You can download the windows version here:
http://irworkshop.com/dl/IRKeystoneWin.zip
(MacOS version will follow a bit later.)
Please give big props and support to Ivan and have a look at his other plugIns here.
For those, who don't know what this is good for:
If you use a multi-screen setup with Resolume Avenue and the projector placement is not optimal, you probably will want to correct the projected image. But correction in the beamers is limited and looks quite shitty, so ... you need this!
VJair
Re: Free Multi-screen keystone plugIn!!
Post by VJair »
i wonder how easy it would be too add more "screens" to the source code?
it could be extremely uesfull for mapping.
Tschoepler
Post by Tschoepler »
Nice. There's a TH2Go session just ahead :D
Thank's for the post and probs to the developer :!:
black_sire
Post by black_sire »
MacOS version - http://irworkshop.com/dl/IRKeystoneMACOS.zip
Enjoy!
And Thanks to MFO!
irworkshop.com
Cool! Nice hack, very useful!
joffo
Post by joffo »
hI
CONGRATULATION ! I love it !
Tecno`
Post by Tecno` »
Thats Great!
We just need a soft edge plugin now allowing for overlaps and then we can project almost anywhere.
Tim
GeeEs
Post by GeeEs »
Tested yesterday! Works like a charm! Even on single screen setups it's possible to do really cool mapping things with these extended keystone plugins!
Thx a lot for sharing!
Stickygreen
Post by Stickygreen »
thank you!
