if anyone know dose Resolume support this card? ''Black Magic Intensity Pro HDMI Video Capture Card''
http://cgi.ebay.com/Black-Magic-Intensi ... 073wt_1139
and if resolume dose not support this video capture card if anyone knows witch video capture card i must to bye to get live video in resolume.
fruitygreen
Re: Black Magic Intensity Pro HDMI Video Capture Card
It works in resolume.
Intensity Shuttle works too.
If used with Atlon VGA to HDMI converter you can mix any computer's output into Resolume.
Some computers that have HDMI out may not work if it has HDCP compatibilty so VGA is the only way. Therefore Atlon VGA to HDMI is needed.
My Toshiba Qosmio Laptop with HDMI out works directly with Intensity Pro capture.
My HP with HDMI and HDCP don't work directly with Intensity Pro Capture. Option was to capture via converter.
Contemplating on getting a Mac so I can get Quartz Compostion into the mix.
My Resolume computer has 2 Intesity Shuttle and 1 Intensity Pro. Can capture anything from composite,component, Svideo, Hdmi and VGA via Atlon VGA to HDMI converter .
Anyways Resolume and Intensity Pro works, but finding the right settings can be tricky.
But its cool to mix other comps and live cams.
how to set VGA to HDMI in windows nvidia control panel?
