[fixed] width and height in clip properties does not work
ondrejsevcik
Post by ondrejsevcik »
hi out-there
width and height in clip properties does not work, it just do nothing.
it used to work some time ago but now it does not.
why?
in layer properties it works ok..
please help.
thx a lot
Re: width and height in clip properties does not work
When you enable the layer width and hight then the clip width and hight are always overridden by the layer. That's probably why you think they do not work anymore.
yochee
Post by yochee »
mmh, same for me. even if i deselect the layer height/width
that is really odd, do you play a video file? Or a picture? Or ...? What exact Resolume version do you use?
ondrejsevcik
hi,
it is the same problem for anything, picture or video..
it works only in preview window - if i click on video's name and it shows in bottom preview window both width and height works fine
when i trigger it into any layer but still have the clip selected width and height just stop working
strange
resolume 3.1.1, 17inch macbook pro, 2.5ghz intel core duo, 4gb ram...
ondrejsevcik
other strange thing is that it automaticaly scales any clip into composition's resolution and there is no way how to change it's width or height - just change the width and height of the layer the clip is in..
please i need this to be solved until friday.. ;-)
ondrejsevcik
one more post - clip's width and heigth works fine in resolume 3.2.0 but in this version there is some problem while connecting my camera sony hdr-hc1e (picture looks like some low-res webcam which is not), anyway this problem is solved in version 3.3.1
but i need both my camera and clip's width/height change :-)
ondrejsevcik
sorry Bart, you were right, i should take some days off probably :-)
thx for your time
adios amigos
Re: [fixed] width and height in clip properties does not work
no problem ;-)
Layer properties that override the clip properties are very powerful but it can also be confusing.
