Hi
What's the best way to do advanced mappings in Resolume? Like this: http://1024d.wordpress.com/2010/10/13/v ... -budapest/
(but on windows)
Alfaleader
Mapping in Resolume
Re: Mapping in Resolume
you can map with Photoshop and resolume. the thread is somewhere probs general chat.
check vjforum for mapping advice there is a lot there at the moment! good luck!
- Tschoepler
try this ffgl plugin viewtopic.php?f=6&t=7275&start=0&hilit=ir+keystone
just for the record, that would be masking, not mappingBasic wrote:you can map with Photoshop and resolume. the thread is somewhere probs general chat.
mapping generaly involves deformation of an image, where as masking involves just showing part of an image on a surface.
alfaleader
Ok, masking != mapping ,another thing I learned.
I know resolume can map with photoshop, but is there a way to use 1 projector for multiple little screens with the same video?
- Tschoepler
sure. duplicate the video inside Avenue and map them to your needs with one of the keystone effects. using some effect like "video wall" additionally would give you more little screens. of course without the ability to map those furthermore.
ah yes my apologiesVJair wrote:just for the record, that would be masking, not mappingBasic wrote:you can map with Photoshop and resolume. the thread is somewhere probs general chat.
