im sure its been mentioned before but it would be great to see nesting / grouping of effects.
basicly - being able to have a group of effects and save them as a single preset and have the benefits of a library of group effects and settings
i was just playing with the IR OSCSA plugins, using them to automate parameters. changing between saved settings allows you to do some great automated functions, but you can only change one at a time. with group presets, you could change between multiple instances at the same time.
grouping / nesting of effects
Re: grouping / nesting of effects
yep +1 this would be great!
There's been a few requests for this before. It's on our radar, but I'm afraid that's all I can say about it at the moment.
is this difficult to add? I presume it will be but it'll still be nice when its done hehe
