Your advice
Godzil
Your advice
Post by Godzil »
How to make the footage to work with interruptions in R3? For example, some logo-footage shows-up for 15 seconds every three minuets?
LUX.visuals
Re: Your advice
Post by LUX.visuals »
How about making a clip of 3 minutes that shows the logo for 15 seconds. Quick and easy :)
Godzil
Re: Your advice
Post by Godzil »
LUX.visuals wrote:How about making a clip of 3 minutes that shows the logo for 15 seconds. Quick and easy :)
What if organizers bring a logo file to you in the middle of performance and there is no time for preparations? That shit happens a lot. ;)
I have few .swf files with dynamic text and i want them running on screens with breakups, not permanently.
LUX.visuals
Re: Your advice
OK, I get it.
You could make an .swf that loads an external image and only shows it for 15 seconds every 3 minutes. The only thing you would have to do is to change the filename and you're ready to roll.
Maybe it's even possible to select the image from the properties box. But i,m not that much into actionscript so this is just a guess.
HerrNieDa
Re: Your advice
Post by HerrNieDa »
on a own layer you can try to use an osc patch like chaos...
you have only 1 clip on the layer but you switch through the empty slots also...
for example
layer with clip
change every 128 beats or so
clip amout is 32 or something
and then sequence this ;)
so you should be able to calculate a time which is fine for you ;)
