Hi all,
I was wondering wich midicontroller everybody was using with resolume.
I use an oxygen 8, but looking for something extra.
Wich midicontroller are u using?
auspuff_
noce_
i use an evolution uc-16. easy and cheap. i don't think keyboard is so imortant on midi cause pushing letters on laptop is almost the same. pitch and slides are really usefull instead of using the mouse...
see here: http://www.evolution.co.uk/products/evo_uc16.htm
henkie_
Digicat_
I have been using the Oxygen-8 for the last year and its usb port finally crapped out on me. I have punished the hell out of that little keyboard too. The knobs on it have lost their glue and the rubber comes off of them now. I am buying the radium-49 though.
Check out the new korg, it has auto triggering of midi events built into the controller...
im buying one of those too.
SuperficiaL_
hi guys,
i dont use midi, i only use a griffin powermate (usb) for the finetuning of the sliders... rest i do with keyboard... works great for me... only 1 knob which controls all the sliders (not at the same time of course...)
also ROCKS for Premiere and other frame related software like After effects and Flash because it can be programmed to work like a shuttlejog...
Greetz Superficial...
- Attachments
- powermate.jpg (2.79 KiB) Viewed 11676 times
themadhatter_
SuperficiaL_
hi madhatter,
its about 5 centimeters in diameter. it has a blue light at the base which u can program to pulse.
a rubber semitransparant base which almost sticks to your desktop.
the usb cord is kinda short around 50 centimeter but usb cords are very cheap these days...
u can turn the knob either way..
and u can even push it...
every move is programmable to a function key, a keystroke or something else.
ehm thats sort of my comercial for this little gadget
i never regretted buying it.
costs 39 dollars
more info here.... http://www.griffintechnology.com/products/powermate
only flaw i can emagine is that it sometimes doesnt recognize the powermate, but this is because i lug my shuttle around and plug it in after i turn it on
but when u pull out the usb cord and reconnect it works fine again...
ah and by the way...
u cant use it for videoscratching (which i had hoped for)
only for the sliders and all the other things that can have a shortcut key asignd.
greetz SuperficiaL...
costs 39 dollars
